Kolink Victory Compatibility Check
10 Jan 2016
Hi,
Not sure if this should be in this section but.
A while ago I bought:
https://www.overclockers.co.uk/ocuk...ylake-micro-atx-ddr4-gaming-pc-fs-152-og.html
I have the i5 6600, 16gb Team Group Vulcan Gold RAM, Gigabyte GTX 960OC, Seagate SSHD 1TB and I have also upgraded my PSU to Corsair CX600M. But now I want to upgrade the GPU. I was thinking of getting either the MSI GeForce GTX 980ti or the ASUS STRIX GeForce GTX 980ti, but was unsure if they would fit (with power connectors) in my case with the location of my hard drive.
Just wondering if anybody could help me out.
Thanks
Hi,
Thanks
Where is the HDD fitted so that it would cause problems with the GPU, is it due to the cage blocking a long card being fitted as if so just make sure their is 30cm space for the card to fit between the PCI-E bracket and the HDD trays.
I haven't seen inside the case but I think it should fit as most cases can accommodate the GTX 980Ti as it isn't really (IMO) a overly long card.
Hope I could help and good luck with you're new GPU :)
