I am making a small build for htpc and casual gaming.
I purchased the case of the title https://kolink.eu/Home/case-1/midi-tower-2/void.html
I havent purchased a motherboard yet.
I've checked that the RGB led controller has 2 ends,one that plugs into a 5 ARGB header(3 pin) and another one that says in VDG.Also to mention,i believe it powered by a sata cable
So my question is,i was planning to buy a B450 tomahawk max/x470 msi gaming plus or a msi 450 A pro max.
I checked none of the above has a 5v ARGB header,or a VDG header.
And i am asking,i have to look for a motherboard with a 5V ARGB header to controll it via the button that it has on top of the case? Or not hooking any cable besides the sata for power will do the work and let me control it via the button?
Thanks in advance.
Below you can find the pictures of the specific cables i am talking about
https://imgur.com/a/y72ReiT
Thanks in advance.
Thanks in advance.
Thanks in advance.
