Koolance PMP 500 Tacho cable ?
14 Sep 2012
Behind you
With my recent bad luck with D5's ( 2 failed inside a week ) I went for the PMP 500 from Koolance, and my god what a sexy looking pump, it is a bit louder than a D5 but from reviews and various tests it comes up better than a D5 in some and level in others. With the only negative ever mentioned is the noise from memory it is about 2 decibles louder than a D5.
My question is pump speed control, it has a Tacho cable, so can I connect the tacho, to my Aquaero 5 LT and be able to control pump speed via the software ? If not is there any other way to control it. In my very limited time in watercooling I have always used a variable D5
PUMP SPECS....
Maximum FlowRate: 16L/min (4.2 gal/min)
Maximum Head Pressure: 7.5m (24.6ft)
Motor: Brushless DC
Power Consumption (at max): 32W
Voltage Range: 6 to 12 VDC
Maximum Temperature: 60°C (140°F)
Electrical Connector: 4-pin Molex power supply connection + 3-pin (single lead) tach
Hose Connections: G 1/4 BSPP Threads
Noise: Less than 50dBA
Weight: 454g (1lbs)
