Koolance QDC confusion
Man of Honour
20 Sep 2006
A while I go I bought the following:
£9.99 x 4 - Koolance QD3 Male Quick Disconnect No-Spill Coupling, Panel Female Threaded G 1/4 BSPP Black
£12.49 x 4 - Koolance QD3 Female Quick Disconnect No-Spill Coupling, Male Threaded G 1/4 BSPP - Black
The intention was to connect them straight up to either my blocks or the rads so I can quickly swap out parts and do maintenance.
However there's no way to do this, I presume I bought the wrong items? I think I also need a compression fitting for the tube end of it too?
Yes, they come with a G1/4 thread to connect the fitting of your choice to suit the pipe/tubing that you are using.
I'm using 13/19mm Tubing, what do I need to connect direct to a block or rad and then the other end to tubing using a compression fitting?
Simplest way is to use the male threaded QDC into your block, then simply a G1/4 to tube screwed into the female threaded female QDC.
Ah so I need threaded connecters to my rads etc (I have compression ones now) and then a compression QDC for the tube end?
