Koolance QDC's... Flow rate
7 Aug 2012
Hi there, I currently have a couple QDC's in my loop which allows me to disconnect the large external radiator for any maintenance etc. Anyway, having bought a couple of new gpu's I am going to have to strip everything down. Having re-designed my loop for easier maintenance in future, I am looking at adding another few QDC's in to the equation... My question, how much do these effect the rate of flow?
I am using a D5 built in to a bay reservoir, currently just have the pump set to setting 1 and everything seems to perform well, but wondering if the QDC's are restrictive to the point I would need to run the pump at higher revs to compensate for adding another couple. My plan is to be able to split the loop up in to 3 seperate parts for easy maintenance. Plan on having QDC's on/ near the inlet and outlet from the reservoir so that I can remove that from the case, a QDC on the inlet and outlet from my GPU's so that I can remove/ replace the GPU's as and when I see fit and also my current QDC's going through case from external rad.
Thoughts?
EDIT: Actually thinking about it, that would allow me to split the loop in to 4 seperate pieces. 1) the reservoir 2) the cpu block and 240 internal rad 3) the gpu's 4) the external rad
Try to go for the QD3 series, they are much more less restrictive.
If you want to go an older generation, the VL series, don't use anything smaller than VL4N, VL2N is as restrictive as a waterblock if my memory serve me right.
The QD3 is just as restrictive as a fitting whereas QD4 is a very good performer - just a bit too bulky
The current QDC's I am using connecting the rest of loop to my external rad are:
VL3N-F13B
and
VL3N-M13B
the female and male part numbers. They seem absolutely fine just now, but I will be adding another 2 of each, so 4 in total.
