- 31 May 2006
- West London
Postman Just delivered a nice box of goodies for me from the US.
First Impressions – worth every penny
Koolance have been making Quick Connectors for a good few years now, and are on the third
revision of their QDC range. The first models were ok and worked well with the external watercooling
systems that Koolance produced. But frankly Zalman’s plastic QC were just as good at a fraction
of the price so the VL2 and VL3 were created to cater for the custom watercooling market.
These not only looked the business but came with elbows, barbs, compression and screw ends.
They also catered for tube sizes up to 1/2 “ ID. The VL2 (low profile) and the VL3 (high flow) are
beautifully engineered but Koolance have gone one better and without much press the VL4 (extreme flow)
is now available in 13mm and 19mm ID!
The Male and Female QC are only available with compression fitting to date and I’m the happy owner
of a pair of the 13mm versions (I’m guessing the 19mm ones are for a different market as I’ve never seen
a pc watercooling loop with this size tubing)
Ok these metal wonders are not cheap – especially with the exchange rate where it is but as
we live in this over priced nation they were just over a £10 more than getting the smaller bore VL3 here.
Up until recently the plastic CPC QC were the low resistance kings – but ugly. These are a major step up
for the plastic zalman’s QC’s that came with my Reservator 2 so I’m really looking forward to installing
them once I’ve got my Fanless tweeks and Mods completed.
Anyway enough with the chat
Big, little box, with lots of packing nuts. P+P was $18 btw with USPS nice
Zip tie bag with goodies inside
Female VL4-F13-19S and Male VL4-M13-19S in their heatsealed bags
Components parts (female on left again)
In locked position – both male and female valves open. 3” long
And yes the threaded ends are a darker gunmetal finish - I like it, looks better in real life than in these images
The forth picture shows the metal peg on the male end and the fifth you can just see the track/groove
that the peg slots into. Both connectors are spring loaded so the when separated, each valves is shut.
Up to a teaspoon full (5ml) of water may escape, so a paper towel is required when disconnecting.
And I guess that a small air bubble in introduced when connecting (unconfirmed)
I'll be swapping the Zalman QC for highflow barbs and using these as the tubing enters my case.
One will have the Male on the outside the other with the female - this way I can connect the two
together to form the de-gassing loop that the Res2 required during setup.
This will also allow me to remove the Case from the wall when I want to tinker without needing
to drain my loop. Will try and get these fitted soon so you can see them installed.
Edit: Some extra tech info from the koolance boffins
VL2 have a 6mm flow-through
VL3 have a 10mm flow-through
VL4 with a 13mm flow-through
The inner springs are stainless steel
Male g1/4 thread on both the male and female nozzles are comeing soon
