Specs
21:9 29"(73cm) QHD Screen
2560 x 1080 QHD Resolution
DVI-D Port
1000:1 Contrast Ratio
300cd/? Brightness
360? Rotation Swivel
General Specification :
Model : CrossOver 290M IPS LED
Respons Rate : 5ms (GTG)
Viewing Angle : 178? / 178?
Input Port : Bypass (Dual Link DVI-D)
Plug and Play : VESA DDC 1/2B
Size : 697 x 420 x 23 mm
Weight : 6.5kg
<Screen>
LCD Type : LG IPS LED Panel
Visible Screen Size : 29.0"/672x283 mm
Pixel Area : 0.0876mm
Max. Brighteness : 300cd/?
Contrast Ratio : 1,000:1
Support Color : 16,777,216 Million Color
<Resolution>
Recomended Resolution : 2560 x 1080 @60Hz
Max. Resolution : 2560 x 1080 @75Hz
<Frequency>
Synchronous Frequency : 30-81kHz
Vertical Frequency : 56-75Hz
Synchronization Signal : TTL, Bipolarity or Negative Polarity
<Power>
Input : 12V 4A
Power Consumption : Minimum 15W / Maximum 35W
Standby Mode : Less than 0.1W
Power Management : VESA DPMS
<Operating Environment>
Power Adapter
VESA Mount : 75 x 75 (not on this version)
