KOTOR 2 Problems
11 Apr 2003
Notts
Hi all, I get a few probs with this game, im running it on:
X2 4800+
2GB Ram
X1950XTX
Windows XP
The game IS fully updated, from the official patches.
I have to disable a core to get this to run, but it does run smoothly, bar the fact that I cant get a good resolution, my monitors are 1440x900, and the highest resolution for this game I can select is 1024x768, I have tried altering the .ini file with no luck is there a way to set a custom resolution?
I also have a problem where the game will crash if I minimize it, and then not load again untill I reboot my PC
Any help apreciated, Much love, Jcb33!
The game runs well on my PC at 1280x1024, though I don't have a wide screen monitor to test other resolutions on. It does sometimes have problems when I minimize it though. It will chug along at about 5FPS with long pauses when entering and exiting the menu. I have to restart the game and it works fine. I've searched and searched and am yet to find a fix. Even the third-party patches (which are essential for completing the game imo) don't fix it.
I'd wait until these guys
http://www.team-gizka.org
get finished with their patch before playing KOTOR2.
It's a great game, but it's horribly, massively crippled. The worst thing about it is that you don't realise this until the last 10% of the game, when you start to realise just how much content was cut to get the game out the door.
That's been in development for so long, I've no idea when it'll be out! Can't get on it from work, but it's one of those mods that probably wont see the full light of day, but would awesome if they did.
