KOTOR II (Xbox 1)
18 Oct 2002
Altrincham
Hi chaps, I've got a weird glitch in this game : Quite near the start when you play as that little robot (T3 is it?) and you go to a "Fuel depot", you need to use a system terminal to open a door IIRC - anyway, straight after the robot gets shot by a massive laser and the screen goes black. Apparently you should then go back to your main character but on my copy it seems like the game sticks on this black screen?
Anyone else come across this problem?
Had this issue as well, I got around it by reloading a (much) older game and trying again. Pretty sure its a known bug if you are playing from a backup on the Hard Drive. Playing with the original disk will also mean you don't get this problem.
You need to play it from disc, not from HDD to avoid the problem, if that's what you're doing.
