Hi, I’m currently using my X61 with my i5-2500K @ 4.5. I don’t use CAM, I believe I just changed the LED colour and then uninstalled it, so fans and pump are running on default settings I guess.
Just wanting to know:
PS. I had a Noctua cooler years ago but it’s too big for the case I have now and I hated how it obstructed the motherboard. So I’d prefer to stick to the x61 if possible.
- Should it work ok with a Ryzen 5 3600 once I have the AM4 bracket?
- Would I likely be able to OC the CPU (nothing too wild) and keep reasonable temps without CAM?
- I’ve heard CAM has issues with temp readings. Is that an issue if I use realtemp?
