Kraken X63 - plug into cpu fan or Pump fan ?
5 Jun 2005
Southampton
Hi all, i have just built a new PC using the MSI MAG Z690 Tomahawk & a Kraken X63, silly question but do i plug into pump or CPU fan ? it's currently in cpu
Leave it in CPU, the pump header is there for the few kits that have the fans and pump cabling split.
Most motherboards will give you a warning on boot with nothing plugged into the CPU header but you can turn it off in bios.
