KRYPTON CROSSHAIR X6 OVERCLOCKED BUNDLE 4.00GHZ
11 Dec 2005
Cheshire
Krypton Crosshair AMD Phenom II X6 1055T 2.80GHz @ 4.00GHz Overclocked Bundle @ £369.98 inc VAT
Designed by experts the "Krypton AMD Crosshair Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
Why You Should Buy This Bundle?
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
Bundle Specification
- CPU: AMD Phenom II X6 1055T 2.80GHz @ 4.00GHz
- Motherboard: Asus Crosshair III Formula AMD 790FX (Socket AM3) DDR3 Motherboard
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Corsair A50 CPU Cooler
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Only £369.98 inc VAT.
ORDER NOW
