- 11 Dec 2005
- Cheshire
Introducing our brand new Krypton G1 Killer Bundle featuring the amazing Gigabyte X58 G1 Killer Guerilla DDR3 Motherboard which ahs Creative X-Fi Audio and Bigfoot Killer LAN intergrated as standard. Designed for the power gamer in mind with 6GB of Corsair XMS3 1600MHz C9 and the new OcUK H2 Flo Extreme with a Sharkoon 120mm 2000rpm fan. All of this for only £519.99 inc VAT.
Krypton G1 Killer Intel Core i7 3.06GHz @ 4.00GHz DDR3 Overclocked Bundle @ £519.98 inc VAT
Designed by experts the "Krypton G1 Killer i7 950 Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
Why You Should Buy This Bundle?
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- 6GB of Triple Channel DDR3 memory delivers unlimited bandwidth
- X58 Chipset provides SLI and Crossfire ready support for any GPU configuration
- USB 3.0 & SATA 6GB/s compatible offering lightning fast transfer speeds
- Bigfoor Killer E2100 LAN Chip & Creative X-Fi Xtreme Fidelity HD sound
Bundle Specification
- CPU: Intel Core i7 950 3.06GHz @ 4.00GHz
- Motherboard: Gigabyte G1 Killer Guerilla X58 (Socket 1366) DDR3 Motherboard
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
- Cooler: OcUK H2 Flo Extreme CPU Cooler w/ Sharkoon 120mm 2000RPM Fan
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £519.98 inc VAT.
ORDER NOW
Service Package
ORDER NOW
