- 11 Dec 2005
- Cheshire
Krypton Intel Core i7 950 3.06GHz @ 4.00GHz Overclocked Bundle @ £549.99 inc VAT
Designed by experts the "Krypton Intel Core i7 950 Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
Why You Should Buy This Bundle?
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 6GB of Triple Channel DDR3 memory delivers unlimited bandwidth
- X58 Chipset provides SLI and Crossfire ready support for any GPU configuration
- USB 3.0 compatible offering lightning fast transfer speeds
Bundle Specification
- CPU: Intel Core i7 950 3.06GHz @ 4.00GHz
- Motherboard: Gigabyte GA-X58-USB3 (Socket 1366) DDR3 Motherboard
- RAM: Corsair XMS3 (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
- Cooler: Titan Fenrir EVO CPU Cooler
- Artic Cooling MX-3 Thermal Compound
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Only £549.99 inc VAT.
ORDER NOW
Service Package
ORDER NOW
