you can ask that or check height with case when you phone your order, they would tell you, i could go and look but wouldn't buy on my say so just in case it didn't
- Dimensions: 439 x 190 x 490mm
fan / heat sink same as mine tbh but i had i7 massive but very very good tbh
Dimensions (with fan): 105 x 158 x 138 mm (W x H x D)
