KTC M27T6. My second attempt at MiniLED monitors.
19 Dec 2010
I posted a thread in here a while ago about the Acer Predator X32QFS. A 32 inch 4k, 150Hz, IPS miniled monitor with 1152 dimming zone. I was very impressed with it but it had a few issues, HDR didn't work quite right and it had a problem with remembering settings when switching modes. The thing that made me return it in the end was the PWM dimming which was causing havoc with my eyes!! However, despite returning it, I thought it was a great monitor. It showed me just how good MiniLED monitors could be, especially when using HDR. And I have been searching for another Miniled monitor since.
Due to work changes, I had to seriously reduce my budget to under £300 and I thought that ended the possibility of upgrading from my current 10 year old Asus MG279Q to either a MiniLED or an OLED. However, last month KTC rode to the rescue with the release of the KTC M27T6. And I purchased one last week. Here are my thoughts on it.
The price is amazing, that's my first thought. For around £260 you are getting the following, a 27 Inch 1440P monitor. HVA Panel, 180hz refresh rate, 1152 dimming zones and HDR1400. I couldn't believe the price when I saw it.
Then I checked to see if it had PWM, as a lot of MiniLED monitors have PWM and I was so happy when I saw the M27T6 has DC dimming. My eyes rejoiced!! :p
Build Quality isn't bad, but it doesn't feel as premium as other monitors. But, the stand is steady, it doesn't take up a lot of room and has all the adjustments you would need. No issues with the that side of things. Next up was checking for dead pixels and please to report that none were to be seen. It's missing a few features, no speakers, no USB hub, no KVM. None of that matters to me personally, but I know for some people those are important. It does have a USB port to do firmware upgrades which is a plus!!
What about the VA black smearing you say? Yes it's there, I doubt most people would notice it. I am particularly susceptible to it and I don't rate it as a problem at all, it's negligible. The viewing angles are poor, typical VA, since it's a 27 inch monitor it's not a problem. When I first turned on the monitor though, I was like this is terrible, the viewing angles were shockingly bad. Then I changed one setting on the monitor and everything was much improved!! More on that later.
More good points. HDR looks amazing on this. Blown away by good it is. It doesn't forget settings either(well not exactly, explain later) The HDR Display mode is so bright and everything looks crisp and clear. It's a feast for the eyes. It has a few different HDR modes, Display, Game, Cinema and a HDR 600 mode if the others are too bright for you. It also has four local dimming modes. off, auto, low, standard and high. The Local dimming is done really well, very little blooming. Other features include MPRT, VRR(can't use both at the same time) and RGB (if anyone actually wants that :) )
What about the bad points other that what I said above? There is some VRR flicker according to reviews. I haven't noticed it yet in game. But it's problem with both VA and OLED panels. The other thing is the black equalise setting. For some reason it's set at 50 when you get the monitor. It makes everything look terrible, washed out, poor colours, bad viewing angles. However when I set it down to 0, everything looked fantastic. So much better. I set it to 10 in games and 0 when using the desktop. There is one other annoying thing about the black equalise. When you change modes, like frorm HDR to SDR or change the colour space the black equalise setting changes. It might say it's at 0 but it's actually gone back up to 50 and you have to raise it in the settings to 50 and back to 0 to get the monitor looking good again. The other thing is the local dimming, auto doesn't work properly when you are in SDR mode on the desktop. It causes flickering when you open and close windows on the desktop. If you turn it off, no flickering.
Will be keeping this monitor. Sure there are some minor niggles and it has the drawbacks of VA, but the positives far outweigh the negatives and the price is just so good!!
This post is underrated. I was about to buy the Xiaomi 24i, but thr god saved me at the last moment. I was about to pay when something came up. Later, I read that Xiaomi has a serious issue with red tint. Lol, even my cheap TN panel looks better than that. So, I found this on Amazon and ordered it after some research. Never buy monitors without checking online first, or you’ll just waste your money.
Well, I spoke to soon. The monitor developed a fault :( So I have had to return it. While playing a game the screen went blue. I could still see the game, but it was like looking through a blue filter. After a few seconds the monitor turned itself off. When I turned it back on, it was ok, but over the next couple of days everything started to get worse, viewing angles, black smear etc. It started flickering too, even with Local Dimming off.
Turns out if had been faulty from the start. Was talking to another guy with the same monitor and he never had to change settings like I had. He didn't have any flicker when setting local dimming to Auto and the Black Equalizer didn't have to be constantly readjusted.
So that's two attempts at MiniLEDs. First Monitor was really good apart from the PWM dimming, And if I wasn't sensitive to PWM I would have kept the Acer. The second one, the KTC was also good, HDR was fantastic on it. Shame that it was faulty :(
Anyway, was seriously considering getting another KTC M27T6, when I saw a special offer on 360Hz OLED. After looking up reviews and doing some reading, I decided to buy it. It will be here Thursday.
Hopefully it's third time lucky!! :p
It's an amazing monitor, as you said. What happened to you is rare and can happen with all brands. It has very positive reviews on Amazon from thousands of buyers. Anyway, you're lucky you were able to return it.
Ah, for OLEDs, make sure the SDR brightness is at least 311 nits. Below 300 nits is bad.
Omg, local dimming adds input lag? I didn't know that. It's funny that my cheap Gigabyte G24F 2 is faster than any Mini-LED monitor with local dimming enabled.
OLED is the best and fastest, with at least 300 SDR nits.
Yes, it does, that has always been the case unfortunately. But for competitive gaming you wouldn't be using HDR or Local Dimming, so it's not a big issue.
Yes, it does, that has always been the case unfortunately. But for competitive gaming you wouldn't be using HDR or Local Dimming, so it's not a big issue.,
No it is big issue for me , iwant perfect black in all situations. I am a gamer. Mini-LED sucks for gamers if you have to turn off local dimming. The perfect display is an OLED. I can see the new Gigabyte with 500hz, support sdr 300 nits 100% window wow
Well, if competitive gaming was your priority, why would you be looking at buying a 180Hz MiniLED VA monitor in the first place? Even if Local Dimming didn't add latency, it still wouldn't be a good choice for competitive gaming because of the VA pixel response times.
And if good black levels in all situations were your biggest priority, then there is only one Panel type that fits that, and that's OLED.
I didn’t know about the added latency with local dimming, I just found out by luck on Reddit, and yeah, OLED is perfect, especially the new one from Gigabyte.
Funny, I just pulled the trigger on this monitor myself. Almost went with an AOC mini-LED but this one has 3x the zones.
I went with it because it's for productivity and gaming- I have the YouTube logo and web browser icons burned in on my OLED laptop, so lesson learned, OLED for entertainment only.
Does this monitor have regular Freesync, or Freesync Premium Pro, considering the HDR capabilities of the monitor?
Kinda wish the HDMI ports were 2.1 instead of just 2.0, but 2.0 should be good for 1080p/120 on consoles, right? How about 1440p?
I saw one review mention it, is this monitor 10 bit?
The HDMI ports will both do 144Hz at 1440p. So, yes, you will be fine on a console at 1080P/120Hz. Display port supports the full 180Hz at 1440p.
It supports VRR sync, no official support for Freesync or Freesync Pro. I had no issues with mine using HDR and VRR sync. It worked perfectly.
It's dithered 10 Bit.
I have the M27P6 which is the 4K 240Hz version, I wasn't expecting much from it but it does seem to be fairly decent though I need more time to test it out. I hate how wobbly KTC stands are though and the base scratches easily too.
Good to know, thanks.
Monitor arrived. It's decent. I would call the matte covering a bit noisy. Make any changes to settings, like saturation, colour calibration etc?
The only settings I really changed were the Black Equalize and the Local Dimming. I lowered the Black Equalize to the lowest it could go before it started crushing blacks. And I changed the Local Dimming from Auto to Off for desktop use. I turned it on when gaming or using HDR. I can't remember did I prefer the low, standard or high mode.
Didn't mess with anything else as I didn't have it long enough.
I'm considering buying an M27T6 as a secondary monitor, my main monitor is a Dell AW3423DW so some of the concerns perhaps aren't really all that relevant to me, mostly I am consdering this as a secondary as I wanted to put my 4K display that I currently use a secondary on my work desk (so this is for my personal gaming system/workstation) and as my main display is 3440x1440 I thought it made sense to get a 1440P 16:9 monitor to go alongside it and the M27T6 can be had for such a good price now, I have never used a Mini LED monitor but I like the idea of it, particularly so that I can keep any documents and such that I do use off my OLED as much as possible and to have access to a brighter display for certain things. Would you recommend it all said and done? ...the HDR capability probably wont really get used tbh as I do that with the OLED main display.
No point in getting a MiniLED monitor if you aren't going to be using HDR. It's only worth considering if you are going to be using the monitor for both work and gaming. If you are mainly going to be using it as secondary monitor for documents, web browsing, stuff like that. Just get a decent IPS monitor.
I mean this monitor is IPS, right? Just with local dimming? I sure have a lot of glow, and not great viewing angles. Probably getting this completely wrong.
Does more local dimming or freesync mess with things like ghosting more? This monitor's ghosting is egregious IMO. Overdrive doesn't seem to do much, or does way too much in terms of introducing artifacts, from my amateur testing. What would be the balance there?
