A few weeks ago i got my antec kuhler h2o RMA'D because it was making EXTREMELY LOUD rattling noises (the pump), It started very quiet, but got increasingly louder.
Now i have a new unit, it is making the quiet rattling noises like the old one did just before it broke.
I have a lian li 120mm fan plugged into the pump, and the pump is plugged into the CPU_1 fan header.
The noise (currently goes away after 5 minutes or so, then it makes the 'normal' slight buzz/hum sound which you cant hear unless you put your ear up to it.
Thoughts on what i should do? I'm worried that this is going the same way as the last one.
Does it matter that i have plugged a lian li 120mm fan (bog standard black fan, nothing fancy) into the pump instead of the original antec one?
Im sure other people do this too.
Hopefully this one doesn't die! a lot of those closed loop coolers must be made of low quality parts as I've read nothing but trouble about all of them.. Corsair, Antec and Cool-it.
