Recently picked up a kuhler 620, not for any real reason other than thought it would look nicer than huge heat sink, while offering good performance.
I am sure when I first installed it that when I was aiming for 5GHz on my 2500K, I was not even breaking 80 C with 1.4V.
Anyway, decided to re-orientate the thing, and add another fan, but I am only trying for a 4.6Ghz oc at around 1.36V, but I am hitting just under 80C on that - typically max 78/79 using IBT Max.
I have to mention that 78/79 is on the 2 hottest cores. Core 0 is typically 10C cooler than those 2, and core 3 is typically 5C cooler.
I have tried re-seating this thing many times now, and have used both MX-2 and Arctic Silver 5, but temps always high.
Or are these temps about right, and I must have imagined the better temps when trying for 5GHz?
For this OC and these volts, I was not really expecting to break 70C. Room is probably around 20C +/-
. Yeah the Antec mounting bits are very fragile I find which not a lot of reviews pick up on. I did the same thing as you and overtightened it at first because there is no feedback telling you that you've done so unline spring loaded screws. It ended up flexing my motherboard and stopped my first RAM slot from being detected so I had to loosen it a bit for testing.
