Kunbuntu with KDE 4 what a pile of crap
10 Sep 2007
I have installed this on my second hard drive and for some reason its decided to put its bootloader on the first hard disk. I now have an old bootloader for ubuntu which doesn't work as the OS has been deleted on the second hard disk and a bootloader for Kubuntu on the first disk.
Does anyone know how to get rid of this without erasing the Windows partition on that disk. I am getting rid of Kubuntu because it a terrible distro. So I don't need to able to boot into it. Its back to boring safe Gnome for me.
If you want to remove grub and put the windows xp MBR back on, boot off of a windows xp cd and press "R" for windows restoration console, select the windows install & enter the administrator password.
Enter the command: "FIXMBR" at the input prompt and confirm the next question with a "Y".
Or if you have a DOS bootdisk do "fdisk /mbr"
I do have an xp disk, but I have Vista on the PC, should it still work?
I have tried booting from the vista disk but in the repair section it asks me to pick a Vista installation and doesn't list any. It give me a chance to load a driver for the hard disk but I don't have one its a just a standard SATA disk.
If you have Ubuntu and Kubuntu on separate partitions you don't need to, KDE and GNOME can co-exist on the same linux installation.
I had Ubuntu on my second hard disk with its bootloader on that disk, I erased it to put on kubuntu, but kubuntu decided it would rather not replace the Ubuntu Grub but install its own on the other disk with vista.
Ubuntu and Kubuntu are the same thing just different wm's in fact they are interchangeable e.g meaning install ubuntu and install stuff for kde turning it into Kubuntu.
You don't want to repair the copy of Vista when booted off the Vista CD you want to open a recovery console. You can then rewrite the MBR using the appropriate commands. I.e. bootrec /fixmbr and bootrec /fixboot
see: http://support.microsoft.com/kb/927392
One of my colleagues had to do this last Thursday to get rid of a broken grub install and get back into Vista on his laptop.
That should get Vista working again then you can look at setting up dual-booting again :)
edit: hmmmm if it can't see Vista is there at all (but can see the disk) are you sure Kubuntu hasn't done something more drastic to it ...
I found that trick on another site and it didn't work because I missed out the space between bootrec and /
That what I call a numpty mistake.
Its working again now, thanks very much for all the info guys.
