Kurgens tight A$$ upgrade
10 Apr 2015
Hungerford, UK, Earth
just wanted some opinions on a motherboard and cpu swap out.
Current system is a Supermicro x58 Server motherboard (not overclockable)
with 12gb ddr3 1333 and an nvdia gt210. The board is USB2, SATA2.
The PCI Express slot has 16x with a 8x slot in line. This I imagine would usually be in a rack case with a PCIE riser. This means that to crow bar a GPU in you have to get a hacksaw to the retention clip :eek: I have just purchased a second hand quadro for use with autocad and revit, but I thought it would be shame to get the hacksaw to this as well..
So , I already have the case, drives, ssd, Quadro GPU, and 16gb DDR3 in a drawer. Would the below be a worthwhile cheapish upgrade.
My basket at Overclockers UK:
Total: £223.48
(includes shipping: £10.50)
or since its not gaming,, I hate to say it , but would AMD offer better value/performance in this £200 area..
Total: £203.48
yes i have that amd a bit older version.... mine is 3.3ghz .... never had issues with just keep a good air flow so it doesnt get hot nothing else
I went for the i5 in the end, and am just waiting on the budget m.2 that was on offer to arrive..
