Hi
I have brought a KVM (see below for the type) and need this to connect up a desktop and a laptop with my monitor and mouse.
The only thing that I have now come across is that due to the (stupid) design of the laptop, the monitor connection and USB connection that plug in to the laptop do not work.
This is because the ports on my laptop are on different sides and therefore the USB connection will not reach as this wire feeds off the main wire.
I am going to need some way of getting around this if this is possible?
I have noticed that you can get extensions but I am not sure if these will work?
If they do work then can anybody advise on what type I will need?
Thanks
Thanks
