KVM question
11 Jun 2003
Sheffield, UK
Can anyone recommend a KVM that has a double tap single key for the switch? Used ones at work that used a double ctrl as the switch and found they made using 2 boxes very fluid (think they were dlinks from memory).
Also Need a kvm that doesnt cause have problems with mouse buttons or repeat keystrokes.
The one i have at the minute only handles mouse 1-3, only takes one key held input (so is pointless for gaming as it cant handle having forward and strafe held at the same time) and stutters as a key is held. Kind of useless kvm for anything other than basic office/web browsing functions.
the belkin 4 way uses scroll lock x 2 then press the up arrow to cycle through screens. Ive got one in work though ive had to reset it once, only had it a week but works 100% usually including my wireless usb mouse (ps2 convertor being used)
kirkster said:
The linksys KVM is ace !!!
Steve
Actually... this might be the one...
(checked)
yeah - theres a cheaper version than the "business class" model that works the same way too so bonus :)
