Hello,
I'm getting a bit confused about what I need for my fairly basic situation.
So fairly common use case in that I want to switch between two work laptops and a personal one with a single press of a button.
Recommendations would be great for actual products, not just the category or type I need. I am looking on Amazon and other forums but there's so many different options and I already bought one item which doesn't quite fit the requirements.
Thank you
Lorna
- I want to switch between at least 2 laptops (but 3 would be the ideal situation)
- Thunderbolt port connectivity for at least one of these plus HDMI too
- Two monitors:
- Main monitor is an LG 40" monitor using resolution 5120x2160
- Second monitor is a fairly basic Benq 27" monitor using resolution 2560x1440
- I have the Logitech MX Keyboard and Mouse which have their own independent buttons on to swithc - but it would be handy if they just switched over themselves but not essential
Thank you
Lorna
