KVM solution needed
17 Nov 2018
Hi All,
Could anyone recommend a KVM unit/dock or other solution to connect x3 machines to a single monitor/keyboard/mouse setup?
1 x desktop
1 x surface book (usb)
1 x Microserver nl40 (vga)
I've been looking for a while and cannot find anything that fits the bill. It seems that a unit is either a laptop dock or a KVM - rarely both. The priority is to be able to switch screen/keyboard/mouse between the desktop and the laptop (and server if poss - but realise this could be a stretch).
Grateful for any advice.
Thanks,
TB
I have heard of Synergy software that seems to do this but i have not used it so can not comment.Hopefully one of the other guys can say if it actually works well or not.
I've heard good thing about Synergy although mostly for shared KB/M input, with separate screens per PC.
It sounds like you need a dock for the Surface and laptop and a KVM to hook up the server. Could you not remote into the server maybe? VGA connection doesn't help matters really...
