KVM switch, but for more than just keyboard and mouse?
2 Oct 2009
Scotland
So I feel I can't be the only person in this situation, but can't seem to find a decent hardware solution after some internet trawling...
I have my personal computer with 2x monitors connected via DisplayPort (1x 4K @ 60 Hz, 1x 1080p). I also have 6x USB peripherals (keyboard, mouse, DAC, mic, speakers, webcam).
I want to be able to switch these displays and USB peripherals between my personal computer and my work laptop.
So I went looking for KVM switches, and it seems most support 2x displays but with only 2x USB 2.0 ports for keyboard and mouse (hence "KVM" I guess!). Most of those also only support 4K @ 30 Hz via DisplayPort (but often 60 Hz via HDMI). There don't seem to be KVM switches that support a larger number of USB ports, let alone USB 3.x ports.
I guess I could find a KVM and pair it with a USB switch, but that seems inelegant
As far as I can tell a software KVM like Synergy only shares keyboard and mouse, not any other peripherals.
tl;dr
I'm looking for a KVM switch that supports:
  • 2x displays (with 4K @ 60 Hz support, preferably via DisplayPort)
  • 6x USB devices (preferably USB 3.x, but USB 2.0 is probably fine)
Does hardware like this exist? Is there another solution entirely?
My old DVI-DL KVM had an extra USB port or two but I'm pretty sure that what you want doesn't exist and your only option will be to use a USB hub.
Your requirements are probably into the realm of more pricey enterprise kind of kit like the Aten brand and so on.
EDIT: You might find some stuff like DACs, etc. don't like being switched between different systems on the fly - which is why a lot of USB switchers/KVMs are designed around just keyboard and mouse.
You could use a USB hub with the KVM for all the peripherals, but no guarantees things like speakers and DACs will play nice with a USB hub.
KVMs that support high refresh rates & high resolutions get pretty expensive.
Have you considered using some kind of remote desktop software instead to simply control the laptop through the main PC?
I'm in a similar boat with just four peripherals that I need to share. My monitors support multiple display inputs so I let the monitors sort out the image, and instead of a KVM I bought a Cable Matters 4 port USB switch with remote. The setup works perfectly. If I had a little more cash to spare, I'd think about purchasing a couple of monitors with USB hub and upstream connections. Something like a Dell P2421.
Search for dual out display port switch and you will get dual port devices around the £100 mark, but they seem limited to 1 USB port which you would likely need to connect a hub to to expand to your ports.
Either way from looking around your going to need 2 device setup.
Thanks for the replies
Bit of a shame KVM switches with lots of USB ports don't exist.
Also, understood regarding the DAC, will set my expectations accordingly.
Having a look at the rainforest, there seem to be some DisplayPort/HDMI dual head KVM options with 4x USB 2.0 ports for ~£130-160 with decent enough reviews. I might give one of those a go and see if I can ditch a couple of my peripherals. Maybe rely on the laptop mic and not bother with the DAC/speakers.
I'm pretty sure that regardless of DP or HDMI (via adapters if necessary) that I'll still get 4K 60 Hz as long as I get HDMI 2.0 or DP 1.4.
@BurningHorizons do you only ever have one computer powered on at a time? I'd guess that would make the display auto source detect work well?
Sorry to dredge up an old thread.
In case it helps anyone else I ended up with the following:
  • 2x port DP 1.4 switch for my first monitor (4K 60Hz)
  • 3x port HDMI 2.0 switch for my second monitor (1440p 60 Hz, bonus 3rd input to let me hook in my Nintendo Switch)
  • 2x port USB 3 switch with 7x port USB 3 hub
I now press 3 buttons when switching between computers and it works very reliably.
Next step is to design an enclosure for the rats nest of wires that I've created and 3D print it!
