- 3 Jan 2004
- At Home
Been looking to source a KVM type switch box that allows 1 computer VGA output to be mechanically switched between 2 monitors & not having much luck.
Just to clarify..... Before anyone suggests a dual display setup type thing
The setup is in a business - with one monitor in one room - and the other in another room. When a user is working the computer in the back room - as a safety precaution, the front monitor needs to be physically switched off using a button/switch unit (to totally disconnect the output to the front monitor) - I know this can be done as I have seen units in action before (but the switch boxes were custom made where the VGA pin-outs were soldered to the switch in a metal enclosure)
Just wondering if there was either a powered/non-powered KVM type thing to support this.
