KVM with network switch ?
Well I'm confused as to what you want...
A KVM with Ethernet ports built in? Or a KVM that allows access over IP?
I'm not sure such a product exists, as I doubt enough power is provided over USB to power both the KVM and the switch. There are USB powered network switches out there, if you don't have another power socket available. You could then tape the KVM and the network switches together for a "ghetto" solution*.
*semi-serious suggestion only.
At 200mbs ?
I've seen them for the old 14 and 85mbs.
*edit*
Doh
I just remebered the solwise piggyback thing had extra ports and is 200mbs
why didn't i think of it :D
