Hi,
I bought a Clio DCI 80 recently and used one of Halfrauds DIY aircon regas kits that came with a pressure gauge. This reduced the air temp loads, but made funny noises from the compressor and its clutch seemed to be engaging and disengaging about every 5 seconds. I then took the car to Kwik Fit to get the aircon done properly with their machine. The aircon system makes no funny noises but is not nearly as cold as it was. It was 7.5 degrees before the kwik fit regas and 17.5 degrees after!
I now find out that I should not have been charged for this as they guarantee that it should be 10% cooler or no charge. Is anyone aware of what might have happened to my aircon system?
Jamie
Jamie
Probably die of pneumonia
