- 20 Jul 2009
- The bleak North East arm pit of Britain
Today we have some very quirky sharp looking speakers ideal for the desktop and on the move. Perfect for finishing off any PC
Kworld Dark Pyramid D4 USB2.0 Speaker @ £14.99 inc VAT
Great Sound with Portability
Triangular Design
- Less reflection, more clarity
- Improve auditory cues in speakers
- Full range of sound and less unwanted echoing
USB Powered
Compatible with all audio sources, such as IPod/iPhone/MP3 Player...etc.
Real Details of Sound
The cavity and the driver are engineered to deliver the optimal Hi-Fi sound accuracy for 2.0 speaker system.
Strong Sound Effect
Dual 8002 chipset for strong voltage transmission, which in return blasts a more rounded stereo sound effect.
Specification:
- Configuration: 2.0
- Total Power: 4 Watts RMS
- Driver: Two 2.5" full-range drivers
- Frequency Response: 120Hz -18KHz
- Signal to Noise Ratio: 65dB
- Dimensions: 138 mm (W) x 120 mm (D) x 123 mm (H)
System Requirements:
An available USB port or USB power adapter
An audio output port for plugging 3.5mm cable
Only £14.99 inc VAT.
ORDER NOW
Kworld Dark Pyramid D8 2.1 Speaker @ £24.99 inc VAT
Great Sound at an Affordable Price
Triangular Design for:
The cavity and the driver are engineered to deliver the optimal Hi-Fi sound accuracy for 2.1 speaker system.
Enjoy really dense bass
The bass driver is designed at the bottom of the woofer for the sound to spread through
Specifications
- Conguration: 2.1
- Total Power: 8 Watts RMS
- Driver: Two 2.5"full-range drivers / 3"long-throw woofer
- Frequency Response: 60Hz -20kHz
- Satellite RMS Power /ea: 2.5" 1 Watts
- Subwoofer RMS Power: 3" 6 Watts
- Signal to Noise Ratio(SNR): 70dB
- Dimension: Satellite:38mm(W) x 120 mm(D) x 123 mm(H)
- Subwoofer:180mm(W) x 180 mm(D) x 180 mm(H)
Only £24.99 inc VAT.
ORDER NOW
Kworld Dark Pyramid D14+ 2.1 Speaker @ £29.99 inc VAT
This well-made sound system is engineered to deliver the optimal Hi-Fi sound quality so that listeners would feel a powerful live-performance experience.
The featured pyramid controller brings you convenience for volume control and save your desk space. Volume command is just between your fingers. It also comes with "Line In" port for MP3, iPhone, iPod, or PSP audio file playback. This smart "Line In" system automatically detects connected audio devices like MP3 player, iPhone or iPod, providing you the enjoyment in convenience. If you want to listen to music with more of the amplifying effect, there is the "Line Out" port for your headset that can serve as the amplifier.
The triangular design of the satellite speakers transmits sound more smooth as it reduces the unnecessary reflection and echoing inside the speakers.
You will hear the real, strong and dense bass because the 4" bass driver is designed at the bottom of the woofer in purpose to spread the sound, making it more dense and real. The sound can be equally delivered into your room as there is a "sound-out" at the rear of the woofer. You can hear the real sound even when you are not right in the front of the woofer. Besides, the woofer is made of metal material that keeps most of heat away, making it more durable.
Features
Triangular Design
The bass driver is designed at the bottom of the woofer for the sound to spread through the ground, making it more dense and real. Wired Controller
The smart "line-in & out " system enables user to use iPhone/iPod or headset to enjoy crystal sound.
Only £29.99 inc VAT.
ORDER NOW
Triangular Design
USB Powered
Strong Sound Effect
Specification:
ORDER NOW
Specifications
- Conguration: 2.1
ORDER NOW
Features
Triangular Design
ORDER NOW
