Surely you just want one of these - http://www.overclockers.co.uk/showproduct.php?prodid=WC-484-BP&groupid=962&catid=2589
With a compression fitting on each end?
Edit - Or just one of these http://www.overclockers.co.uk/showproduct.php?prodid=WC-499-BP&groupid=962&catid=2589 then you don't need the separate fittings.
oh nice one! didn't think of looking in the bitspower section.
so you can use what mole said, unless you decide to create a drain, then use the T fitting.
but if you're using soft tube, won't it just hang with the weight of the fitting?
GODDAMNIT I LOVE YOU MAN!!!!! Thanks a bunch! It never occurred to me neither to look in there lol.
I'll show you what I mean once I've done it but it won't hang or sag I assure you.
yeah you would have thought that they'd still include it with the rest of the fittings!
and actually yeah now I think about it, if you measure it properly it shouldn't.
That's for acrylic (rigid) tubing, it won't work with regular tube![]()
