L4D2 servers
12 Nov 2002
Herts
I got bought this game for Christmas to try and persuade me to play it but i've only been able to connect to 2 games the first kick us out after about 20 mins and the second I had a ping of 1400 which went down to 700. Now i'm unable to connect to any server, I can't even create my own game it just keeps giving me an error of connection failed after 10 retries. :confused:
My firewall is turned off as it affects Steam, I've tried rebooting my computer and the router but still doesnt work.
MW
did windows pop up with it's usual "should you allow this program to access network"
but anyway use the ocuk servers.
insanity mod
mm_dedicated_force_servers 217.163.30.155:27015,217.163.10.204:27015
vanilla
mm_dedicated_force_servers 94.23.222.136:29021,94.23.222.136:29025
There's a few more but I can't remember them >.<
just put them in console BEFORE you start the lobby.
I've terminated every process that wasn't vital to running windows and it still doesnt work.
I'm able to play a locally hosted game but nothing on the internet :(
I've also reinstalled the game.
How ?
MW
How ?
MW
Enable console in options. then press ` in the main menu paste in those commands then start a lobby.
just like console in css if ytou ever played that.
if you add me o nsteam quickly i can try inviting you onto a server just to check if you do it quckly
Update:
Apparently those errors in the console and failing to connect to any servers are caused by the update. I un-installed Comodo and Steam including all the games and re-installed Steam and LFD2 and it's working :)
MW
Im having this problem and it's been doing my nut in all night, connection failed after 10 retries is all i keep getting i have tried all the helps and tips online for the last 4 hours to no avail, I can create my own lobby fine but not connect to my mates or any other.....What should i do next im at my wits end honesty i really need some helpp pplllleeeeaaaassseeeee
