My employer is looking at options for housing ~40 laptops for student labs in a secure cart solution that would re-image and charge each device overnight. Their idea is that the base Windows image would be from another laptop or local domain server (e.g. CloneZilla). Students could then use a local login for various experiments and projects but responsible for their own storage.
They generally want to avoid heavy maintenance for updates etc where all updates and software installations are done in the base image before labs. I had suggested a local domain with SCCM would be more suitable but they'd prefer standalone laptops as they could be lent out when labs weren't on.
Do any of you use a similar setup for multiple laptops? Budget would likely be under £3000 for the cart but might be persuaded to increase depending on teaching requirements.
