LaCie XtremKey All-Terrain Flash Drives Pre-Order ***AS SEEN ON THE GADGET SHOW***
17 Oct 2002
Stoke
For those of you who watched The Gadget Show last night you will know that Lacie's latest XtremKey featured in the Top 5 rugged gadgets. OcUK have now got them available to pre-order and will be arriving in around a week. :)
LaCie XtremKey All-Terrain 8GB USB 2.0 Flash Drive @ £39.99 inc VAT
The XtremKey is LaCie's strongest, toughest USB key yet. With an impenetrable shell, the LaCie XtremKey is a truly rugged USB key that stands up to the elements. The XtremKey is constructed with zamac, a metal alloy composed of zinc, aluminum, magnesium and copper that’s so strong, it can withstand the pressure of a 10-ton truck. The XtremKey’s memory modules are shielded inside of a 2mm casing and sealed with wear-resistant screw threads and a rubber O-ring, which makes it watertight up to 100 meters. In addition, it’s resistant to 5-meter drops, fierce heat and bitter cold—it holds up in any environment, no matter where you take it (+200°C / -50°). Equipped with the Hi-Speed USB 2.0 interface, the LaCie XtremKey offers instant compatibility, outstanding transfer speeds and cross-platform convenience to all PC and Mac users. With speeds up to 15MB/s (write) and 40MB/s (read), you don’t have to sacrifice performance for protection.
- Full metal casing - 2mm thickness
- Heat-, cold-, water-, pressure- and drop-resistant
- Outstanding write and read performance
- Wear-resistant braided metal cable ring
- Warranty: 2 Years
Only £39.99 inc VAT.
ORDER NOW
LaCie XtremKey All-Terrain 16GB USB 2.0 Flash Drive @ £62.99 inc VAT
The XtremKey is LaCie's strongest, toughest USB key yet. With an impenetrable shell, the LaCie XtremKey is a truly rugged USB key that stands up to the elements. The XtremKey is constructed with zamac, a metal alloy composed of zinc, aluminum, magnesium and copper that’s so strong, it can withstand the pressure of a 10-ton truck. The XtremKey’s memory modules are shielded inside of a 2mm casing and sealed with wear-resistant screw threads and a rubber O-ring, which makes it watertight up to 100 meters. In addition, it’s resistant to 5-meter drops, fierce heat and bitter cold—it holds up in any environment, no matter where you take it (+200°C / -50°). Equipped with the Hi-Speed USB 2.0 interface, the LaCie XtremKey offers instant compatibility, outstanding transfer speeds and cross-platform convenience to all PC and Mac users. With speeds up to 30MB/s (write) and 40MB/s (read), you don’t have to sacrifice performance for protection.
- Warranty: 2 Years
Only £62.99 inc VAT.
ORDER NOW
LaCie XtremKey All-Terrain 32GB USB 2.0 Flash Drive @ £102.99 inc VAT
- Warranty: 2 Years
Only £102.99 inc VAT.
ORDER NOW
i'm looking for a new one, as my old one is the slowest thing on earth rocking along at a massivr 900k per second.
it's between this and the Voyager GT.
might need a bit more than 8gb though.
I personally don't think the Voyager comes anywhere close to the XtremKey. Corsair have the Survivor range for that.
The XtremKey is LaCie's strongest, toughest USB key yet. With an impenetrable shell...
So, er... does the warranty cover any damage or is it just marketing tosh? I'd love to see just how tough they are :p
