got this question in my assignment,
For part of a washing machine cycle a solenoid valve should open to fill the
drum with water. It is then to be switch off once the level has been reached at
which point the heater will be switched on for 10 seconds. The heater is then
switched off and the drum rotation motor started running at low speed for 20
seconds followed by high speed spin for a further 20 seconds. The cycle
should be started using an ‘on’ switch, run automatically and terminate once
the drum rotation motor has completed the high speed spin.
this is what ive done for it,
image hosting gif
don't think its right. especially when dealing with the solenoid on off technique i used
any advice??
thanks
image hosting gif
any advice??
thanks
