Lag during Dota
7 May 2010
Newcastle
Hi guys. My spec is as follows,
Intel Core i5-4690K
AMD R9 380
Samsung 850 Evo 250GB
Kingston HyperX DDR3 2400 C11 2x4GB
I've been running dota 2 seamlessly for over 2 years, now ive booted my pc and launched the game and i'm getting pretty bad intermittent lag during play. I initially thought it was CPU lag as ive had problems with my cooler in the past but having ran a CPU temp programme none of my cores are going above 32 degrees.
Im a bit stumped so I ran a GPU benchmark programme and got the following results
UserBenchmarks: Game 46%, Desk 69%, Work 40%
CPU: Intel Core i5-4690K - 80.9%
GPU: AMD R9 380 - 45.4%
SSD: Samsung 850 Evo 250GB - 92.9%
RAM: Kingston HyperX DDR3 2400 C11 2x4GB - 33.8%
MBD: Asus Z97-K
The memory seems to be running slow and I got this message on the report - Performing below potential (7th percentile) - ensure that a dual+ channel XMP BIOS profile is enabled
I also ran a speedtest and my net was running at 35 download and 8 upload so that kind of eliminates that problem. Im not one for tinkering with anything so nothing has changed since I last had a game 2 days ago when it ran dota perfectly.
Any help would be greatly appreciated, thanks.
post the mem results ie
2 of 4 slots used
8GB DIMM DDR3 clocked @ 2400 MHz
and from multi core
MC Read 30.9
MC Write 33.6
MC Mixed 27
87% 30.5 GB/s
sounds like bios has reset to defaults , switching off xmp profile
Hi, thanks for your quick response. I can confirm that the bios had XMP disabled, which I went ahead and enabled on profile 1, however having launched dota again this doesn't seem to have resolved the issue.
Here are the results having enabled XMP
2 of 4 slots used
MC Read 16.8
MC Write 16.9
MC Mixed 13.9
45% 15.9 GB/s
Thanks again lude1962
I just had a look through the bios and I couldnt see anything which would suggest dual channel wasnt enabled. Although my knowledge of the bios and how to navigate it is fairly basic.
My ram is installed in the 2 slots closest to the CPU cooler, they were marked in the bios as the following.
DIMM_A1
DIMM_A2
Thanks
Should I move one stick over one slot and re-try? I haven't changed the slots since a friend first built the PC so im confused as to why it would start lagging all of a sudden, strange!
Ok ive changed the ram over however the lag is persisting. Ive re-ran the benchmark with the following results;
Intel Core i5-4690K
53,147 User benchmarks - Average bench 80%
SOCKET 1150, 1 CPU, 4 cores, 4 threads
Base clock 3.5 GHz, turbo 3.9 GHz (avg)
Performing above expectations (66th percentile)
AMD R9 380-£173
19,965 User benchmarks - Average bench 44%
Sapphire(174B E308)
CLim: 985 MHz, MLim: 1450 MHz, Ram: 4GB, Driver: 17.1.1
Performing above expectations (84th percentile
Samsung 850 Evo 250GB-
163,263 User benchmarks - Average bench 94%
52GB free
Firmware: EMT01B6Q Max speed: SATA 3.0 600 MB/s
SYSTEM NCQ 4KALIGNED SSD TRIM S.M.A.R.T
Performing below expectations (29th percentile)
2,239 User benchmarks - Average bench 57%
2 of 4 slots used
MC Read 30.9
MC Write 30.2
MC Mixed 25.1
82% 28.7 GB/s
Performing way above expectations (91st percentile)
Everything seems to be running as expected, im starting to wonder if this is a settings problem, maybe ill try unistalling dota and re-installing. Worth a try?
Thanks for your help, its greatly appreciated.
Well a clean install of Dota hasn't achieved anything. I'm really puzzled by the benchmark test showing me everything is performing as it should be.
