- 2 Dec 2012
- Lincolnshire.
EDIT 2: I am now lead to believe that this might be a motherboard issue / fault. Something to do with the PCI-e slots not communicating with the GPU properly, and sometimes the random voltage spikes and warnings from the MB probes when nothing is actually changing and also because BIOS settings which I change don't actually work or change anything...
EDIT 1: I have tried dragging an explorer window around (My Documents) on Windows Aero and the lag issue is there, however I turned over to Windows 7 Basic and the issue has completely gone in it's entirety. <- Confused.
So I made a thread a few days ago about having lag issues in Windows 7 but after countless hours and sleep lost of troubleshooting, working my fingers to the bone on over 100 different programs (not literally), I've just reach the point where I'm about to give up.
System Specs:
CPU: Intel™ Core i5 3570K (Ivybridge) @ 4.6GHz
CPU Cooler: Corsair H80i
Motherboard: ASUS Sabertooth Z77 (LGA1155)
Memory: Corsair Dominator Platinum 16GB (4x4GB) @ 1600Mhz
SSD #1 (Boot Drive): Corsair Force 3 120GB
SSD #2: OCZ Agility 3 60GB
HDD #1: Samsung Spinpoint F3 1TB
HDD #2: Seagate Barracuda 500GB 6GB/s
GPU: MSI GeForce GTX 660 Ti OC 2GB
PSU: Corsair HX850W Modular 80+ PLUS Silver Certified
Optical Drive: LG 22x DVD/RW
Case: Corsair Carbide 500R
Problem Description: So essentially my computer in general is lagging. This is not program specific, it's just a general lag. Everything from just dragging the blue highlight boxes around on my desktop to dragging chat boxes around, explorer windows around, browser windows around, it's just a terrible lag. Sometimes it runs smoothly, but every now and then it stutters with lag, and it gets worse and worse each day. At random points too my system audio / network just turns into robot mode, for example I was in a Skype call not 1 hour ago and randomly all of a sudden everybody just turned into robot and the audio stream was stuttering on and off just like a high frequency / fast strobe light.
It's getting to the point where I can no longer do anything. I went on a game and fraps was saying I was getting 70-90 FPS but every second or two it would lag bomb down to about 5-10FPS (without fraps indicating that), and my mouse input would be so delayed, by around 0.5 - 1 second.
Troubleshooting Steps Taken:
- RMA'd GPU = Got a new one, same problem.
- Memtest = No errors.
- Overclock = Ran stock and OC, Both have the issue.
- PSU = Not causing the issue.
- HDD's / SSD's = Not causing the issue, stress tested under benchmarks.
- Reformatted onto a clean Windows installation = Same issue.
Can anybody shed light on this please? My computer is important to me and my studies (I do 3D modelling).
System Specs:
