I have built a new watercooling system consisting of the following:
1 x 360 XSPC RX rad
1 x 120 TFC rad
1 x Swiftech XT i7 block
2 x EK gtx470 full cover waterblocks
1/2" tubing.
I used my old Laing d5 pump with v.2 top.
Now, I had major issues with the new setup in getting it to bleed and feed the pump properly (don't ask but I started again and moved where everything was and it all works fine now) and there was short periods of 10 seconds or so when the pump was running dry (I know, not a good idea
However, looking at the reservoir the water going in is not much more than a slow tap. Now with my old system consisting of a xspc cpu block and only a swiftech double rad (although I had two ek gpu blocks so no change there) it was very forceful and caused major turbalance in the reservoir.
So they question is have I knackered my D5 pump when at times it was running dry or is my new loop too much for the pump?
Easy ways of checking whether the D5 is knackered please?
If the loop is too much, can somebody recommend a suitable pump please?
1 x 360 XSPC RX rad
1 x 120 TFC rad
1/2" tubing.
