Im deciding on pumps for a watercooled rig, what would be the best choice of the two above? Ive considered the D5 vario with an aftermarket top, (EK d5 rev2) and using an ek multi option res, but ive seen the laing ddc with the xps res top, initially i just want to cool the cpu, (i7 920 DO), gpu's are out of the equation as i might be changing my sli 275's shortly. Case is a Lian Li A70F, i know il have to get another top case panel (or send my current one away) to be modded for a radiator, thermochill 120.3 15mm spacing im thinking off. The cpu block im considering using is the full copper heatkiler.
