Laing dcc 1 plus flow direction
17 Jul 2008
Potatoe
hi I've got an xspc dual res which takes two pumps I'm going to run them both on the same loop but I can't figure out which way the pumps go in.
obviously the pumps go at the bottom of the res but I want them both pumping in the same direction not against each other.
so would I be right in presuming that if I have them both with the wire on the right they'll pump liquid the same way round the loop?
I've read the instruction manual & it doesn't say :(
I don't think you can put them in the wrong way, whichever way you put them in the centre bit still rotates the same way and they can only pump out of one hole.
Or did I miss something?
