laing ddc 18w pump quickie
Yes, all it does it tell you the speed the pump is running at. I plugged mine into the CPU header which I also set via the BIOS to turn off the PC if the pump (motherboard reads it as a fan) turned off or dropped below a certain rpm. A handy little safety device.;)
