Model name: Laing DDC-1 (9W)/Inline 12vDC Pump
Nominal Voltage: 12 VDC
Operating Voltage range: 6 - 13.2 VDC
Nominal Power (@12 V): 8.3 W
Nominal Current (@12 V): .69 Amp
Motor Type: Electronically commutated, brushless DC, spherical motor
Maximum Head: 13.05 ft (4 m)
Maximum Discharge: ~ 92.4 GPH (350 LPH)
Connection Size: 3/8" barbs
Maximum Pressure: 22 PSI (1.5 BAR)
Temperature Range: Up to 140°F (60°C)
Noise Level (Swiftech's Results): 24 ~ 26 dBA in a quiet room @ 2'
Electrical Connector: 4pin Molex
Weight: 7.3 oz (207 gr.)
RPM Sensor: 3 pin connector
Model name: Laing DDC-2 (18W)/Inline 12vDC Pump
Operating Voltage range: 8 - 13.2 VDC
Minimum Starting Voltage: 9 VDC
Nominal Power (@12 V): 18 W
Nominal Current (@12 V): 1.46 Amp
Maximum Head: 20.2 ft (6.1 m)
Maximum Discharge: ~ 120 GPH (454 LPH)
Noise Level (Swiftech's Results): 30 ~ 32 dBA in a quiet room @ 2'
Since the DDC pump has become so popular and now is generaly always recomended over the D5 and 50Z(wich also are very good pumps), that is with the modifed tops of course, ive decided to collect all info about the pump in one thread.
DDC is known to be more silent than both D5 and 50Z while it outperform them both!
The pump is known under different names and there may be a little confusion out there since there also is a couple of different version of the pump. Ive collected the names beneath... There is also a 11W version but its the 10w\18w wich is normal and being sold now so i consentrated about them:
There is now a new revision out wich has a blue impeller with a bit smaller hole in it. The layout of the pump semes to be the same for both ddc1 and ddc2 so both can potensially be changed to the other. Read more Here(german)
Different 10w names(with and without tops): ddc-1, mcp350, ddc pro,
Different 18w names(with and without tops): ddc-2, mcp355, ddc ultra, ddc+, ddc 1t-pluss
The pro and ultra is actually alphacool names and describes the 10w and 18w with their top
How to spot the difference between 10w and 18w:
10w got a black impeller and 18w got an orange impeller
There is also some holes in the impeller of the 18w but if you spotted those youve already noticed the orange color of it
Aslo added some places to buy this pump, there is ofcourse a lot more but here is some atleast
Warning! There seemes to be som fake ddcs going around!
Read more here!
*Don't link to competitors*
And this pump doesnt show its real beast without a modded top. the top is what really makes this pump
and you can read some of this tests to see why and how well it performs
Tests:
Petras test of Petra\Alphacool\Radiical tops, also including 50z
H2Okoelings test of standard\alphacool\water tank top(danish)
Systemcoolings test of 10W
The Alphacool\watercool tops can even be modified a bit for a little more performance, its just about enlarging the inlet hole as is a little small
original. Just remember not to over do it as bigger aint always better
Here is a few links to people @ xs who modified theirs:
Nickhsub1
Andersson.j
Trice
Here ive listed every top wich is avaliable, except from the originale of course
Different tops:
There is also been some pumps with starting issues, you can discuss it more
Here
I have studdyed these a lot as i need 7 in my rig!
Hope this help guys
Pete
Read more here!
Tests:
Nickhsub1
Andersson.j
Trice
Different tops:
Here
Hope this help guys
Pete
