I made a pilaf last night using this recipe.
http://www.grouprecipes.com/34920/uzbek-lamb-plov-pilaf.html
Pretty much all pilaf recipes I looked at invlove inserting a whole head of garlic, with just the bottom chopepd off, in the the top layer of rice as it is cooking and leaving it for the last 15 or so minutes.
Apart from the obvious flavour going into the dish by leaving it there, what are you supposed to do with the garlic afterwards? I am assuming you DON'T mash it all up and put the whole thing into the dish as that would be a lot of garlic. Some recipes suggest mashing it and using it in a dressing or other side dish. Since I wasn't bothered about this, I just fished the thing out and chucked it away, but this seems to be quite a waste.
Next time, could I just put a couple of cloves in and mix it all together and get the same flavour overall?
