Laminate flooring thresholds
25 Nov 2009
Morning all,
I have used Howdens fast fit v groove in the downstairs of my house but I cant find a suitable threshold to finish it all off with... I need something that'll span one double door opening around 1600mm and 3 doors at ~800mm obviously all the same stuff.
I've used American Pecan, it's an odd shade that the generic oak/pine etc looks silly with so I'm not sure if I'll maybe have to go with brushed stainless/aluminium to match the fixtures and fittings?
Any idea's, it's doing my head in now!
Cheers chaps :)
What about just a piece of wood/pine that matches your architrave?
Not sure I'm with you Russ, you mean to get a generic threshold and paint it satin white like the architrave? I should imagine that'd wear quite quickly...
lots on fleabay.not your exact colour but might be worth a look.also seen 1 at 2.7m
Not considered eBay tbh. I have been through Wickes/B&Q/Screwfix etc and found nothing really suitable... Wickes looked good as they have loads of different shades, 900mm lengths though :/
Should the threshold be screwed down or does in just sit there?
Most clip into a U shaped channel that you screw down
As above another solution is to get a piece of solid wood strip and stain it to suit :)
