My current carpet in my room is naff. It needs replacing. I'm looking to change it for as cheap as possible.
The area of the room is 10.57m2.
I would probably need someone to fit either laminate flooring or the carpet. Would it cost around the same price for someone to fit? Or would it be cheaper with a carpet fitter? Also, how much am I looking to pay someone to fit carpet/laminate (roughly).
I noticed you can get this flooring for only £3.77 / m2:
http://www.ikea.com/gb/en/catalog/products/20275569/
Which only comes to £45.20 for the size of my room, then add around £15 for the underlay - what else would I need if I go down this route?
Ta
Ta
