- 30 Nov 2010
- UK
Hi,
Got this today from Ocuk, molex is plugged in and got two 3-pin fans connected to the 3 pin fan connections channels 1 and 2 (not using temp sensors) but did connect a couple just to check I didn't have to use them for it to work. Lights come on the fan controller yet fans don't move, fiddled with dials yet nothing any ideas?
Fans are standard corsair case fan 120mm that comes with 650D and a 200mm Bit Fenix spectre pro.
