Just wanted to know if anyone has had the problem of the onboard lan controller being stuck in "Deep Sleep Mode".
This is due to a Sleep/Hibernate problem where certain components are unable to wake up after resuming a windows session and it means that your unable to connect to the internet as windows shows no connections also network adapter is missing in device manager.
Unfortunatly due to me not having any internet access i tried to do a system restore but windows said it wasnt active and i couldn't turn it on so i had to re-install windows which i was glad i did as it gave me the oppurtunity to get rid of loads of crap.
After i re-installed windows i still had the same problem until i managed to find a fix off the internet at my friends. Basically i did a google search and was directed to another forum.
I was told to shutdown my pc and remove all sticks of ram and leave them out for at least 10 minutes then put them back in and startup the pc and that should make the Lan controller wake from deep sleep and to my surprise it did just that.
So i thought i would come here and tell you all about this just incase you have the same problem and need to know a fix for it.
