LAN Party Cube
14 Jan 2007
Shuttle system for LAN Parties
Components already purchased:
Asus A8V-VM SE Socket 939
BFG 7900GTX
Corsair 2GB Kit (2x1GB) DDR 400MHz/PC3200 Memory CL3
Maxtor 250GB SATAII
Plextor DVD ReWriter
Aspire X-QPACK Black/Silver Aluminium Micro ATX Case with 650W PSU
Looking for a CPU & Cooler. Budget - CPU £80, Cooler £35.
Looking to o/c CPU upto 3ghz if possible.
Any thoughts would be very much appreciated.
the athlon x3800 is going cheap the now £47, they can oc well, from anything from 2.3 to 3.0ghz or an opty 170 @ £ 87. both (939) dual cores :)
coolers, £ 35 should get u a good 1, thermalight ultra, scythe, Noctua
as for going for 3ghz, maybe these chips would do it if good o/c, would look about 2.5-2.8ghz ave on most of these cpu.
g/l
As you may imagine size is a problem for coolers in that case, the best you'll be able to fit is the Zalman 8700. As for CPUs, the 4200+ is a pretty good bargain at the moment.
