Hey all
I've just got some 'slightly' n00b questions but I feel after a Google I'm getting nothing concrete, so was wondering anyone here knowledgeable can input some info.
My network is currently running from a WRT54G which I believe is 10/100, which is then run to two 10/100 switches and then the computers are attatched to the 10/100 switches. I am using Cat5 cable.
1) If I want to have Gigabit speeds across my internal network, I would need to change the router to a Gigabit one, along with the switches needing to be changed also wouldn't I? Can Cat5 handle Gigabit speeds with no problem?
2) If I decided to upgrade one section of the house (one switch) to Gigabit Switch and left my router and the other switch as it is... I assume that it means anything running off the new Gigabit switch will transfer at 'Gigabit' speeds and anything transferred from the new switch to a PC on the old switch would be at the lower 10/100 speeds (due to the old 10/100 switch).
3) If I were to leave the network setup as it is, and detatch one pc off it... connect a gigabit switch and then connect two pc's to the Gigabit switch - the transfer between the 2 pcs would be at Gigabit speeds?
4) If using the PCs (say the entire network has been upgraded) to transfer files, will it impact my internet performance? Say I am transferring 10GB of photos to another computer at relativley high speeds across the network, will that bottleneck the internet speed for the other PCs as its in use?
Thanks
Thanks
