Lan - surely not hard!
Permabanned
19 Apr 2008
SE London
I am having some problems with the wireless on my BT Home Hub, so I am trying out a cable directly.
Normally, I thought this just connects automatically, but now its not.
When I go to network connection wizard, it says it cannot find my network hardware - is this even the right thing to do?
I thought that with a HomeHub, or any router, the internet is always 'shooting' down the cable, which then instantly connects when connected with a computer.
Can anyone tell me why this is happening? I am at a bit of a loss! :(
Thanks Guys!
Normally with a network cable it just works, you wont need to use connection wizard.
when the wires in try doing an ipconfig /all in the command prompt and see if your assigned an IP
