Lan through the mains electric socket
Permabanned
30 May 2006
Just to make sure I have got this right
If I get one of this electrical wiring adapters all I need to do is connect one next to the router with a lan cable and the other one anywhere I want and that would work? are there any issues with this technology?
Thanks
Simple as that, and much better than wireless!
It is a virtual cat5 cable running from adapter A to B. How you use it is up to you.
Router -> adaptor A -> adaptor B -> computer is a possible combination, yes :)
Most powerline kits allow you to just add more plugs to extend your network, as they each individually route traffic themselves rather than just acting like a bridge. Check with your particular model first, though.
What I want is for the machines connected to be having their own IP address. If the main adapter is 1 and the output to the router is also 1 i dont see how several Ip addresses can be assigned?
I assume you mean you want the machines to have routable IP's?
It should be possible, however, I think each powerline adapter would need a routable IP, also.
